@Maxcicon - I ordered this...
Aluminum Intake Reducer 3.5" OD to 3" OD: Intake Hoses, IntakeTubing, and Intake Clamps
@alaxfire - I also ordered these...
1' 45 Mandrel Bent Aluminum Pipe (Four of them)
1' Straight Aluminum Pipe (One of these)
2' Straight Aluminum Pipe (Two of these)
Silicone Coupler Hoses (Six of these)
Washable air filter media. (Two of these)
3.5" Exhaust Clamp (One of these)
3" T Band Clamp (Thirteen of these)
I will be using the 1 foot pipe to go THROUGH the T Splitter, cutting a 2" diameter hole above the 3" opening, then cutting 1 inch spaced "notches" around the inside to the full 3" diameter. Push the 1 foot tube THROUGH the splitter, then reach in the Throttle body hole and bend those DOWNWARD to create a sturdy, 3" diameter hole. Then I will take a hatchet and bend a notch ABOVE that whole, to create an inward bend, directing the air towards the throttle body. It's SUPER custom, but I think it will all work out. I'll let you guys know how it works and post pics if it does!!!!!!
