Choppy
This is bad advice there is no Kenwood deck that outputs 50W rms per channel. If it’s a newer deck it’s rated at 22W per channel however all independent test has rated it at 13-14W of useable power per channel.
If its rated at 22W RMS then thats what its constant "usable power" is. I dont agree with 13-14W (Kenwood would have been sued in this sue happy country). In which case it outputs the same as the stock amp, which in turn makes it good advice. Why use the amp if new decks put out the same.... There is also more reasons than just bypassing the amp. You cant argue with quality, having the rear subs hooked to the rear output of the deck and the front to the front, you then get adjustability which you dont have right now.. Also, if the output is less then why did I get more bass out of the subs and overall better quality?????????????? hmmmm....... (Im still almost positive my manual says 50W RMS, but Ill get back to you on that)....
