Old Jul 30, 2012 | 03:25 PM
ala_xfire
Default Re: Coolant loss due to idiot previous owner... LOL
Originally Posted by Semlinger
How do you get the tank out of the car? I have an srt-6 and have taken off the two nuts that hold the tank to the mounting studs. That allows me to shake, pull and pry on the tank but it will not come loose/out. Iit seems too set on a pedestal (that is part of the tan)k and that pedestal seems to go thru a rubber grommet and then thru a hole in a metal painted bracket welded to the car. I was afraid to shake or pry harder because I did not want to break the tank. How do you get the tank out? Thanks
All you have said is correct. Over time, the nipple from the tank gets stuck in the grommet that is mounted in the metal bracket, best thing to do is take a large screwdriver or pry tool and just pop it out. First time I removed mine, the grommet came out of the bracket before the nipple came loose. I used some silicone grease when I reassembled, and it popped right back in with no problem.
