Old Aug 1, 2012 | 01:27 PM
TerryR's Avatar
TerryR
Default Re: Safe to removal under hood insulation?
Originally Posted by Indycrossfire04
Ok, I've got a stupid question...I just bought a 2004 XF coupe and after new tires, stereo with Bluetooth, and an escort RD I'm kind of tapped out...call it because of the recession. Anyways...the black engine insulation panel mounted to the underside of the hood is falling down on the engine cover. Is it safe to just remove it instead of paying the $300 for a replacement? My old car didn't even have this. The only other car I've even had with this was a clk 55 several years ago. So can I safely remove it and not worry about it? Recommendations?
Up your neck of the woods it MAY not make a lot of difference, BUT in Houston, apart from reducing the engine noise, it ALSO reduces the transmittance of the 100+ degrees outside temperature, also heating up the engine bay, adding to the usual high underhood temperature. THIS COULD be a serious problem. ???
