Old Aug 2, 2012 | 09:28 AM
BoilerUpXFire
Default Re: "tips and tricks" ?
Originally Posted by Jackerman
I read the throttle reset in a DIY ,how would you disable the chime?
1)Turn key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt.
2)Start engine and wait for the seat belt light to turn off.
3)Within 60 seconds unbuckle/rebuckle the seat belt 3 times - ending with buckled, you will hear a single chime (sometimes this verification chime is slightly different just the same it works to disable the chime).
This confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function."
Disconnecting the battery will reset the chime and you'll have to do it again!
