Re: line lock for burn out and launching
I make a half a dozen passes or more per week on Mickey Thompson ET Street Radials. I don't have problems going through rear brake pads. It doesn't take much brake pedal pressure to hold the car
The car doesn't walk sideways when doing burnouts either, burnouts and launches are pretty straight. I DO HAVE a Wavetrac rear end and that probably helps quite a bit. At 0* rear toe I found the rear wandered back and forth a little under hard acceleration with the drag radials. I adjusted it back in to just 1/32 toe-in and that was all it took to keep it solid.
