Re: Any 2006 convertible owners with rear window falling out problem?
Dear Janaiy,
I actually just joined so I could respond to you. I have an 06 in which the glass just started pulling away from the top. Both sides are totally ripped away and working on the bottom portion. I am in the process of dealing with Chrysler Corp. It shouldn't matter if this is an 06. They extended the warranty to the 05 because of this problem. Although ours is an 06 it was made in 05 but still should not matter. Fact is it is the same issue all around. Also if you notice....they used some form of glue when in actuality it should have been a weather bearing epoxy. Epoxy is what is used on the front windshield so no clue why they used a glue on the back when you don't have a solid frame like the front. Usually an upholstery shop is where you would take it for the repairs and I was told 300-500 for it. The glass guy told me it would be fixed with an epoxy. I don't know my outcome yet but I will fight tooth and nail for them to fix this on going problem that the convertibles have...hope I was some help
