Jackerman
yes your check engine light will be illuminated after the ecu detects multiple misfires , forgot how my instructor on school explained that one to me..but atm you have no Cel so your culprit couldnt be most any of those , I'd say start with what was suggested above
Vacuum check first , if no leak is found go for the mounts
Do you know what values should be showing while reading them @ engine idle thru OBD ?
I have an ELM327 (bluetooth) and i can monitor the engine while at idle for you to check if there is a problem with any sensor/something else ...
Tell me if that could be useful because as i don't have another engine like this by hand, i can't be sure of anything !
