Thread: The A/C Saga
Old Aug 6, 2012 | 08:30 PM
RL67037's Avatar
RL67037
Default Re: The A/C Saga
Originally Posted by DJ Dax
Thanks RL..I will have a look at that...before I had it regased the A?c was not working and after the same..just mormal air temp..the chap said he did not know what the problem was..but it was fully charged..I ran it today and the pipe was just normal...no cold at all.
Thanks
Dax
When your A/C clutch engages, does it stay engaged throughout or does it cycle on and off - possibly several times a minute?
With your low side hose not getting cold, it could be over charged or under charged. You mention that when you had it re-gassed it was 75%. Did the re-gassing bring it up to 75% or was it at 75% before re-gassing and then the re-gas brought it up from there - to I'm guessing 100%? What pressures were you reading before and after the re-gas and what kind of gauge set up was used to read these pressures?
When you had it re-gassed, how many ounces of freon did your mechanic put in?
Thanks - RL
