Old Aug 6, 2012 | 08:34 PM
  #53 (permalink)
x4kevin's Avatar
x4kevin
Default Re: Engine Quit & Left Me On The Side Of The Highway
I appreciate the help very much. The car goes into limp mode or idle. At first I would feather the throttle and it would jump to life but at risk of launching into the car in front. Now when it goes to limp, just turn it of and it cranks and fire almost immediately. maybe require a second attempt. When its cold and it idling in the driveway it will sputter and die but starts right back up. Took it up a very steep hill to see if it craps put at high rpm and it did cough a couple of times but very minor. The error code is map sensor, high and low voltage detected. I think it was p0103 Scanner said it was pending??? The more I think about it the more it sounds like mas. Any tests that can isolate the problem. Got a nice Bosch cps installed and over kill on the soldered rcm
