Thread: Coolant leak
Old Aug 11, 2012 | 02:56 PM
onehundred80
Default Re: Coolant leak
Originally Posted by dinasrt
I'd say yes, if the leak is inside theCAC. It's welded shut with no other place to go right? But if the leak is at the point of connections outside the CAC, then a small leak would just probably evaporate away with little to no evidence I would think.
Thanks for the reply, if it was leaking outside the CAC would the fluid be visible or would the Sc have to be removed to see the residue left from the dried leakage. I tend to think the SC would have to be removed.
Edit
I can see no build up of dried fluid when I peer with a flashlight under the SC around the inlet and outlets pipes.
I am waiting for results from Blackstone Labs on the oil analysis.
