Re: Engine Mount (Polyurethane Fill)
ummm did you read the poly thread? your mounts are toast . toss em. you were supposed to drill a small hole in the top of the mounts i sent you and drain them. then mix the poly which is in liquid form and fill the mounts i sent to you. after 24 hrs the poly hardens and seals the hole. THEN install them
the main objective of the poly is to replace the oem fluid with a semi solid poly fill that wont drain out
