Coolant leak
Aug 13, 2012 | 06:29 PM
26
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Re: Coolant leak
Oil report from Blackstone came today, and it said low wear and no coolant in the oil. HOORAY for that.
But where is it going?
This question for the brains trust on this forum, if it is the CIC would I see it in the intake plenums? They are as clean as a whistle as I stated before. Just a little oil that was sitting on the gasket and in the gap between the rubber hose and the SC 'Y'. From all accounts gunge in the plenums should be evident, there is none at all and I have only just installed the oil catch can a week ago.
There is no leak visible under the SC from the coolant going into the CIC.
No leaks in the rad or hoses going to it. There is no smell of coolant in the car so I have dismissed leakage from the heater core.
In 24,000 miles I never had to top up the reservoir on my NA at all.
I will be at Woodward as the oil is clean.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
