DarksideXF
Jessejames, by far my favorite xf! What are the wheel specs?
Thank you! Black sure is nice looking, at least for a day or two after a wash and wax. Here is what she has as pictured above;
Front-
TSW Max 19"X8.5" et 43mm with 12mm hubcentric spacers for an effective 31mm offset, wrapped in 245/35ZR19. The OEM springs were cut 7/8 of a coil and 1" off the shock bumper and 5 dot spring pads.
Rear-
TSW Max 20"X10.5" et 40mm offset with 15mm hubcentric spacers for an effective 25mm offset, wrapped in 285/30ZR20. The OEM springs had 1 full coil cut off and 1" off the shock bumper with 4 dot spring pads. MikeR adjustable camber arms and sway bar links with modification to the body seam to allow increased upward travel of the sway bar.
