Old Aug 14, 2012 | 01:45 PM
magneticred's Avatar
magneticred
Default Re: Resetting service odometer
Make sure when you do the reset procedure that you turn the key to the on position, not the accessory position.
From the owner manual:
1. Turn key to the ON/RUN position.
2. Within one second press the reset button (22) twice.
3. The present status for days or distance is displayed.
Within 10 seconds turn the key to OFF/
LOCK.
4. Press and hold the reset button (22), while turning
the key to ON/RUN again. The present status for
days or distance is displayed once more. Continue
to hold the reset button(22).
After approximately 10 seconds, a signal sounds and
the display shows 7,000 miles (Canada: 11,000 km) for
approximately 10 seconds.
5. Release the reset button (22).
