Originally Posted by HDDP
Bobs: Somehow I knew you would have the answer... The yellow lines appeared to be air lines... So, when you're saying it will trip the MIL, are you saying the Check Engine Light ? Or will it make the car generally unhappy ?
The interior of the doors, windows, locks etc are getting gutted as well. And MOTEC won't have the computer done for the car for at least another 9 months. Should I just leave the pump in place for the time being ?
It's going to take a few weeks to gut the car, cut the lower part of the dash, remove the interior accoutrements and then have the interior sand blasted and painted, but I still have some track events in the interim... Should I keep this thing wired-in ?
HDDP, It looks like the locking pump is pretty tightly integrated with the security system so you might be opening a can of worms if you decide to pull it. Of course, if you're gonna put a MOTEC system in then all those other boxes are kind of redundant, aren't they?
That being said, I probably wouldn't mess with it until the MOTEC system is ready to go in. BTW, how are those SRT-6 brakes working out for you?
Here's a quote that comes from page 8Q-46 in the manual:
Geek mode on:
The "SKREEM" is the Sentry Key Remote Entry Module, which is located behind the instrument cluster. Also, pay close attention to the "Siren" section. Things could get a bit noisy if you pull the CLP/SSM.
VEHICLE THEFT SECURITY - SERVICE INFORMATION
DESCRIPTION
The Central Locking Pump/Security System Module (3) uses a combination of electrical wires (2) and air pressure/vacuum lines (1). The Central Locking Pump/Security System Module is located in the right rear of the luggage compartment underneath the trunk floor covering (4). It is wrapped in a sound deadening material in order to operate quietly without disturbing the vehicle operator. The Central Locking Pump/Security System Module controls the air and vacuum lines that handle the locking and unlocking
of the vehicle doors, the liftgate, and the fuel tank door.
OPERATION
VEHICLE LOCKING/UNLOCKING
To unlock, the Body Control Module is actuated by the SKREEM. The Body Control Module then sends the signal to the Central Locking Pump/Security System Module (CLP/SSM) via the Controller Area Network (CAN) Bus. The CLP/SSM pump motor starts running and supplies air pressure. The door lock actuators are pressurized. When a pressure threshold is reached in the system, the pump is switched off by an internal pressure switch. The pressure in the system is then released by the CLP/SSM and the unlocking operation is completed. The locking procedure is accomplished in a fashion opposite to the unlocking operation. However, the next time the remote control button is pressed, the CLP/SSM is also actuated by connecting it to ground by the second control lead on the SKREEM. The direction of rotation for the CLP/SSM pump motor is reversed, thereby providing the vacuum required to lock. In order to avoid unlocking the vehicle unintentionally, the vehicle is relocked by the CLP/SSM via the SKREEM. Relocking is accomplished after unlocking with the remote control when: a door is not opened within 40 seconds, the key is not inserted into the ignition lock, the interior power door lock switch is not actuated, only the liftgate is opened after unlocking. The CLP/SSM reads the signals (door contacts, trunk lid, interior power door lock switch) and actuates the power door lock actuators. The vehicle security alarm is also activated by the relocking function.
AUTOMATIC LOCKING/UNLOCKING
Upon reaching a speed of 15 km/h (9 MPH), the vehicle doors are locked automatically. The fuel tank flap remains unlocked. If, after automatic locking, the vehicle is unlocked with the interior power door lock switch, this state is maintained until a door is opened or until the ignition is switched off. Automatic locking is accomplished again only upon reaching the specified speed. The logic circuitry for this function is integrated into the CLP/SSM. The automatic locking function can be activated or deactivated with the DRB IIIT. An alternative is to use the interior power door lock switch with the ignition switched on by pressing and holding the door lock switch for more than 5 seconds in either the lock (auto locking switched on) or unlock (auto locking switched off) position. The alternative of enabling/disabling the auto locking system by using the interior power door lock switch can also be inhibited with the DRB IIIT.
EMERGENCY UNLOCKING
In the event of a vehicle collision, the doors are unlocked automatically by a crash sensor integrated into the CLP/SSM. The doors are unlocked after a delay time of 8 to 11 seconds. The emergency unlocking function interrupts all functions performed by the CLP/SSM, which are reactivated only after interrupting the ignition. The emergency unlocking function is only active when the vehicle is unlocked from the outside.
VEHICLE RELOCKING
In order to avoid unlocking the vehicle unintentionally, the vehicle is relocked by the CLP/SSM via the SKREEM. Relocking is accomplished after unlocking with the remote control when: a door is not opened within 40 seconds, the key is not inserted into the ignition lock, or the interior power door lock switch is not actuated. The CLP/SSM reads the signals (door contacts, interior power door lock switch) and actuates the power door lock actuators. The vehicle security alarm is also activated by the relocking function.
ANTI-THEFT SYSTEM
Once the anti-theft alarm system is set, the anti-theft alarm can be triggered if:
² The doors, hood, or hatch is opened
² The radio is removed (disconnected electrically)
² The ignition is jumped
² The glove box is opened
² The anti-theft tow sensor is tripped
² The alarm siren is tripped
The inputs ready for triggering an alarm are checked twice per second by the CLP/SSM. If two sequential checks of the same input indicate that the input is not in the non-actuated state, the audible alarm Siren is triggered and the front and rear lamps flash.
SIREN
The vehicle theft system alarm Siren contains a built in rechargeable battery back up and can sound if its electrical circuits are disconnected or if the vehicle battery cables are disconnected.
The Siren can also sound if the electrical circuits between it and the CLP/SSM are disconnected. Once triggered, the Siren can only be silenced by unlocking the vehicle with the RF key transmitter or by unlocking the vehicle with the mechanical key.
ANTI-THEFT SWITCH/ANTI-THEFT TOW SENSOR
The Anti-Theft Tow Sensor is an inclination sensor that contains electrodes which are partially immersed in an electrically conductive liquid. If the conductive value between the electrodes changes, the sensor recognizes a change in the inclination of the vehicle. When the vehicle is parked, the value for the vehicle position is stored. If the vehicle is moved with a certain inclination in longitudinal and/or lateral direction for a certain time when the anti-theft alarm system is activated, the Anti-Theft Tow Sensor transmits an alarm signal to the CLP/SSM. In order to allow the vehicle to be towed or transported without sounding the alarm Siren, the Anti-Theft Tow Sensor can be deactivated by pressing the Anti-Theft Switch which is located in the passenger compartment on the center console in front of the shift lever.
