Old Aug 15, 2012 | 09:19 PM
  #38 (permalink)
simkard's Avatar
simkard
Default
Originally Posted by oledoc2u
Crankshaft Position Sensors fail on a lot of other cars as well.... It will display rough idle, or will cause the car to die. It will continue to get worse until it fails altogether. Usually a rough idle is consistant with a vacuum leak. So even though all those hoses look connected, it can have cracks in them not readily visable. Check the throttle body bolts haven't loosened up... You really need to do a good inspection by removing everything out of the way....and reconnecting everything...good luck...
Hi,
Thanks for these precious informations.
For now, i received the sensors, but, i still haven't received the female TORX for the various screws on the engine.
I will post as soon as possible to keep you all in touch of the resolution, or not, of these rough idle problems.
See you !
