Old Jan 25, 2006 | 10:55 PM
HDDP's Avatar
HDDP
Default Re: Now I'm Really Confused (oil)
Thanks BOBS: I'm going to wait till the last bit, before I pull it out... I think I'm going to use the space on the right where the pneumatic pump is now located, for the required halon tank. It looks like I can get a nice sized fire system in there...
The SRT6 brakes are 50% OK... As I mentioned, I only purchased one front (driver side) rotor, caliper etc. for a test... It bolted on fine and then I removed it. So I ordered the driver side rear a week ago. This should arrive at the end of the week. I will test that one when it arrives. If it bolts on as easily as the front, I'll purchase the entire system.
I'm trying not to screw myself, since the parts are non-returnable... At least I know that the fronts will work. Let's see if the same is true for the rears...
