Old Aug 17, 2012 | 11:44 PM
closer9's Avatar
closer9
Default Wow! Just did the 3M headlight restoration.
Only did one side. Too tired to do the passenger's side. Would like to get some daylight comparison pictures too. I had no idea my headlights were so bad until I did this. Not sure if I want to go HID's now, or just run Silverstars for a while. The headlights were so hard to change on my last car, I never messed with them in the 3 years I owned it.
I know there are other threads on this, but didn't see any with close up pix. Thought others might like to see. I plan on doing the foglights as well, but will see about removing them from the car, since they sit somewhat recessed to the bumper. Getting into the tight point near the bottom of the grill was a little difficult with the large diameter wheel they give you.
BTW, if you're going to do this, use LOTS of tape. I used 2 layers of masking tape then another 2 layers of duck tape, and kept the duck tape close by. As soon as I noticed a wear spot in the tape I added another piece or two.
