Old Aug 19, 2012 | 10:31 PM
GraphiteGhost
Default Re: Oil warning light / odometer missing?
You also might try one of those engine flushes just before an oil change. If sludge is the culprit it might break up enough to let it work properly. I run a qt of kerosene (generic engine flush) before all my oil changes and I have never had a sludge problem with any of my motors since the early 70's. If it pleases you you can use that 'sea-foam' stuff, whatever breaks up sludge should be OK for the motor. Kero residuals will 'burn' off after a few miles leaving your synthetic all by itself after you change it.
