Old Aug 24, 2012 | 02:50 PM
ala_xfire
Default Re: Could this be something other than CPS or RCM?
Easy alternator test :
If you don't have a voltmeter/multimeter, go get a cheap one from Radio Shack or WallyWorld. ( you can also get a digital voltage meter that plugs in the lighter socket from most any auto parts store ) or :
http://www.ebay.com/itm/LED-Display-...ht_3533wt_1397
I just ordered 4 of those, total was $10.86
1. Measure between battery terminals with car off : should be 12.0 - 12.7 volts.
2. Start it up, should now be around 14.7 Volts.
if 1. not OK - then charge the battery and try again.
if 2. not OK, then alternator issues.
