Old Aug 26, 2012 | 07:38 PM
onehundred80
Default Re: AC blows hot? Weird idle/lope at start? Fixed mine!
Originally Posted by martyfa
MrMopar
I've had problems with my AC for awhile as well. Always blowing HOT!! Checked the gray vacuum line like you suggested and it looks and feels fine on the engine compartment side but after pulling glove box out found a small nick in the same line and repaired that. Still blowing hot. Any other ideas?
You have to see if the blend door is working. The line may look fine, but is the door working?
Does it blow hot when the engine is cold?
