rmaier
my mods
62mm S/C pulley
custom 3" DCAI
2 h/e's in serial
custom pulley setup for belt slippage
oil catch can
8.5mm magnacore wires
2 steps colder plugs
removed resonator
Eurotune
4th gear pull only netted 342 rwhp
My 65mm pulley with the same mods was at 328 rwhp
remember this is done at an altitude of 5382 so figure that along with humidity at 8% and 92 degrees F
29.64 bar and the adjusted rwhp would be 369
My best at Bandimere was 13:11
That was with the 65mm pulley and all the same mods above minus the resonator delete.
Its very nice to hear from someone else at this altitude. How much boost did you make with 65mm and 62mm pulleys? How are your IAT's? Why did you drop the plugs 2 heat ranges? How did the tuning go with Eurocharged at altitude?
T
