bieber
I need a couple of parts & some help, please.
1) I just took a rock to my passenger / right side foglight, anybody have one?
2) My car has been missing the access door to the drivers / left side foglight since I bought it. Again, anybody have one?
3) Any advice on removing and replacing the passenger / right side foglight assembly?
4) Does anybody have the M-B part number for the 2004 engine accessory drive belt tensioner? The idler pulley is on the cross reference list, but not the tensioner. Also, has anybody had a good experience with any aftermarket (Gates / Goodyear etc..) replacement belt tensioners? I do not want to install something with the wrong tension and ruin bearings in any accessories.
Thanks
1) Go to
Car-Part.com--Used Auto Parts Market / enter vehicle info and hit search. You'll have good luck there. Call some the "$Call" locations. I did, got the assembly for $60, no tax, no shipping.
2) Car-part might have these as well, but you would probably need to talk to someone and describe it. If you go to the dealer, here are your part numbers:
Right / Passenger side - 05097958AA
Left / Driver side - 05097959AA
3) You can change these lights through the access door without removing the wheel or lifting the car. You will need to turn the wheel all the way to the right to get enough room. They are held in by three (3) Torx type screws, I think they are size 25. You can do it by feel. Once you get the new assembly in hand, use it as your road map as to where the screws will be located. I did mine in about 20 minutes - just take your time.
4) Sorry, don't have the M/B part number for that.
RL
