Re: Mystery no start issue
Guys, I'm stuck (literally in my driveway) and need some help! I've got the same issue-turns over three times, begins to fire, then dies. After that, nothing when I turn the key unless I disconnect the battery and/or wait a while, then the same thing. I've read the entire thread here, plus anything else I can find on the site. I've re-soldered the relays (or, rather, a pro did), checked the battery for full charge, tried both key fobs, and nothing helps. Could it be the transponder ring itself, and is there a test for it? Is there anything I'm missing or something else I can try? I'm out of ideas, myself, and about to give it over to the stealership.
Thanks.
