Another update from the Polyurethane Engine Mount project:
I have completed the jig to hold both mounts at once and will be sending this jig along with the other mounts to whomever wants to do this to their old mounts.
I have made it adjustable in height so that you can utilize the larger mounts like the ones sent to me. It does take into account the fifteen degree angle on the bottom, so it will keep the mounts level during pouring.
I will probably be milling some more material from the top bracket to make room for pouring the polyurethane tomorrow, but mostly it is done.
The next thing will be drilling a hole to drain the passenger side mount and then hog out some rubber, maybe on the mill. Not sure if I want to try and cut that by hand yet.
Until next time... Cheers!
