Old Aug 29, 2012 | 10:32 PM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: Engine Mount (Polyurethane Fill)
Another little update for those who are still following this...
I finished the jig. Once done I see that there is not quite enough material removed from the center 'post' of the mount.
I will probably be hogging off some with the mill once I get the piece secured in the rotary table. If I can secure the base I will be removing more from the inner wall as near to the outer metal sleeve as I can.
Some of the articles have suggested burning off the rubber, but this is ecologically unsound.
There are factory rivets in the mounts that were used to fill them with fluid. I will probably just drill them out and tape them over before pouring the polyurethane.
