Thread: Too much funk?
Old Aug 30, 2012 | 12:41 PM
onehundred80
Default Re: Too much funk?
Originally Posted by JHM2K
I'm going to check tonight. Until this morning I didn't consider the I/C failure but I did a search for oily intake manis (which lead to threads about intercooler failures) and found several references to "guacamole". And that descriptor is perfect, because that's exactly what this feels like.
I know that at a glance, the coolant hasn't appeared abnormally low so I'm hoping Rudy's assumption that this is a pin-hole leak is correct. Perhaps isolating the I/C fluid from the engine coolant will lower the pressure enough to at least slow the leak.
Still sucks.
Boiling of the water and leaving what you have spread around plus what was burnt would indicate a fair amount of loss.
I expected something like that but all I found was a thin film of oil on the gasket edges and none visible in the plenums. It was a big relief to me as you can imagine.
