Thread: Too much funk?
Old Aug 30, 2012 | 06:38 PM
dinasrt's Avatar
dinasrt
Default Re: Too much funk?
Originally Posted by JHM2K
Perhaps isolating the I/C fluid from the engine coolant will lower the pressure enough to at least slow the leak.
If you're going to truly separate the systems (not just valve them off), you could run straight distilled water in the IC circuit so you're only ingesting a little H20 instead of antifreeze/coolant. Depending how much it's leaking, it might even cool you down a couple of degrees, lol.
