Thread: Too much funk?
Old Aug 31, 2012 | 01:18 AM
JHM2K's Avatar
JHM2K
Default Re: Too much funk?
Originally Posted by dinasrt
If you're going to truly separate the systems (not just valve them off), you could run straight distilled water in the IC circuit so you're only ingesting a little H20 instead of antifreeze/coolant. Depending how much it's leaking, it might even cool you down a couple of degrees, lol.
That's actually a brilliant thought. May have to consider that
Would your reservoir mentioned earlier be adequate?
