Thread: Too much funk?
Old Aug 31, 2012 | 11:10 AM
JHM2K's Avatar
JHM2K
Default Re: Too much funk?
Originally Posted by dinasrt
I'm not certain what you mean by adequate. This little tank (a used BMW power steering reservoir off of E-Bay) or any tank that you decided to use is simply a means to fill and monitor the separated IC system. I run w/ straight distilled water and one bottle of DEI water wetter. It's very cool to be able to remove the cap and actually see the pump pumping, or dip your fingers into and be amazed that it doesn't burn you after you've just done a few hot laps. It's a great solution for those of us that haven't gone with a supercooler that has a fill cap. The whole setup cost me about $30. and a couple hours of time. There are a few more pic.'s in my gallery if that helps.
The setup you have is a good one, I'll switch to it no matter what because it's clear the intercooler can't handle the extra pressure.
Originally Posted by 32krazy!
i know you dont want to hear it john but you have to replace the i/c if its bad. separete the system is a good idea, but band aid ideas and racing just dont mix. if you are going to mod and race either road race or drag things will break. you just fix it and move on.
i can come over sun and rip it apart and get everything ready for a new i/c if you want
as a thought you could install 3 of these for the price of a new 1. call and see which has the lowest mileage
Search Results
I can always count on you for tough love, hahaha. I emailed Tim (MrMoPar) yesterday, haven't heard a peep but I can't wait long. Hoping he has something and can hook a brother up with expedite shipment.
I recommend you buy a used intercooler and have it pressure tested before it's installed. Here you go:
Thanks for the link. I noticed they're mostly in Canada, one in NY and I plan to call them in a moment. Is there anywhere locally that does pressure-testing?
bad luck man.
umm want to sell your 1/2 mile spot?
I know, I know... damn vultures.
Nope, I'll be back up and running by then. If nothing else I'll button it all up, run it down the half mile spewing glycol out the tailpipe till she pops.
Then drop a match in the car, walk away and buy your SLK 55 when you get the Cayman S
