Old Aug 31, 2012 | 12:09 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Bridging the stock amp
What about wiring in two each 4 ohm single voice coil 6" subs rated at 100 watts RMS? How do I get the lowest possible ohm load to increase power but not risk damage to the stock amp?
Also, if the stock amp is replaced, how is the wheel speed sensor output to the body control module and controller antilock brake (pin 3 plug B) and the power top control module (pin 2 plug B)
