Thomas Barbaruolo
Our 06' has started doing a few strange things. 1: Driver's seat moans and groans when adjusting it in any direction. You would think an elephant was sitting in it. It does this even if no one is sitting in it while adjusting! 2: The wing goes up when starting the car without depressing the button. 3: The radio will play without the key in ignition. 4: Alarm sometimes goes off when entering even though it's unlocked. Has anybody go any ideas why this is happening? BTW, it has just over 26K miles and we live in the Phoenix area of AZ. Thanks!
Hope this helps.
1. Try lubricating the tracks for the seat. Also, check to make sure something isn't stuck under there making it bind.
2. If you have the original battery, you may be experiencing the battery gremlin. Weird things happen when the battery is going bad. Even if it appears to be OK, it may be going bad. The spoiler is one of the indicatros.
3. The radio is designed to play when the car is off. HOWEVER, if it's doing it all the time........ again, could be the battery.
4. Check out threads on here regarding the Alarm. Do a search. there are several possibilities.
Good luck.
