Re: Alignment Tutorial Needed
The camber and toe is adjustable up front you just need to find someone who knows how to do it. With the camber you have to loosen the camber bolts and pry on the arm and get it where you want it. Our guy was doing the toe with 2 wrenches, nothing special.
I have -1.8 camber on both sides and Toe is straight, 0 degree maybe id have to check.
Ill try and get you more information when I get off work
