I guess if you pried on the control arms you might get some adjustment on the front camber.... but the camber is not adjustable(on either end of the Crossfire). You can get the MB bolts that will give you a couple of tenths of a degree change and works for some cars... the Kmac kits for the front has poly bushings that replace the factory bushings in the control arms and have eccentric bolts that give you plenty of adjustment...they are about $350 - $380 I believe...
