waldig
Thanks, The antifreeze can be many colors , mine is the prestone neon green. The color I see is a combination of water-anti freeze and oil vapor making a slurry. The stuff has coated the passages and caused the poor performance. Woody
Stands to reason this could be the reason I was getting a poor idle and a P0105 code. The P0105 is the whole reason I'm diggin into the manis, because I had to remove them to access the MAP sensor.
When the car cranked and idled fine, she ran like a raped ape. Trick was, getting it to idle.
No wonder the MAP sensor was on the blink...
