Re: What do I need ... Looking to return to OEM intake, from NEEDSWINGS
If you still have the oem set up you should be all set other than the piece you need that goes between the radiator. Do you have the hose that goes on the oem intake?. You can find the install pdf. file here in post#2 that shows the hose I'm talking about and any other parts you might need.
https://www.crossfireforum.org/forum...tructions.html
