Old Sep 1, 2012 | 07:05 PM
IBLUBYU's Avatar
IBLUBYU
Default Re: What do I need ... Looking to return to OEM intake, from NEEDSWINGS
Originally Posted by robby363
If you still have the oem set up you should be all set other than the piece you need that goes between the radiator. Do you have the hose that goes on the oem intake?. l
Robby .... Thanx for the linky to the install. That helps..... As mentioned, what ever was changed/removed during the install by the prev owner, I don't have!!!! I have an OEM intake set-up that I picked up at some point, but it didn't come with the original intake breather hose, OR the plastic radiator pass-thru piece. It also looks like I may need a couple of remount brackets(maybe) for the horn and the shorter bracket/clamp for the radiator cooling line.
