Thread: 2006 Roadster
Old Sep 2, 2012 | 02:58 PM
James1549
Default Re: 2006 Roadster
Originally Posted by ewaynec
He also said that you cannot just take out the old one and put in a new one. There are things to be done before and after.
Actually you can just take your old battery out and install your new one with no problems.
But the garage will probably plug in a 'memory saver' to your OBD2 port while changing the battery to save any pre-set radio stations you have. The Crossfire radio does not need a 'code' nor reprogrammed.
Also most of the time, the ESP/BAS light will be 'on' the dash after a battery change or dead battery. Simply turn the steering wheel lock to lock and that will go away.
James
