The Beep
32, The info is not all over this forum. I know the tune won't add hp. My understanding is the tune will increase fluid pressure causing the trans to shift harder. Since I drive on inconsistant roads and not the track, I'm concerned about the faster shift (1-2) throwing the car out of control under WOT. Neither you or anyone else has answered the question.
Also, I realize there was an issue initally with the rev limiter and that it has been addressed by EC.
there is info on both forums because i posted it. i tested the tcu for over 6 months. if you truly think the 1-2 shift would cause the car to go sideways you havent driven the car the way it sits anywere close to its potential. so theres no reason to do any kind of tcu mod.
the rev limiter was only part of the issue.
mbworld the c32 forum has posts all over it concerning the tcu mod.
the best answer is dont do it. other than that your on your own.
