simmie777
Hi all,
My father's N/A crossfire has recently been experiencing a rather strange issue. He will be driving along and then suddenly all the warning lights will come on the spoiler would raise followed by the car switching to limp mode.
I will be taking it to a shop today to see if it is throwing any codes but I wanted to put the problem out there to the forum members before I take it in.
From some inital searching I found a similar issue relating to the transmission conducter plate. Does anyone tend to agree?
Thanks,
Michael
I know this sounds too strange to consider, but you may want to look for pooling water that's leaked into the "well" of the trunk area. Tell-tale dampness under the rear deck cover immediately after a rain may be the tip off. There are some electrical devices (locking system vacuum pump) and connectors that can get wet/corrode and cause some odd and intermittent problems. Ask me how I know this
While its next to impossible to find out where a leak come in, there is a plug and low-point drain hole that the stuff can drain out.
