How many bearings?
My Xfire was recently diagnosed with bad front wheel bearings after a failed alignment attempt. I read enough forum posts on the subject and after reading though the service manual decided I was going to do it my self.
A quick stop at NAPA and my first question came up. They list inside and outside bearings. After viewing the parts list and rereading the service manual I noticed that only outer were pictured or described. On the forum it seems that only outer are discussed.
I've only ever worked on pressed in bearings. So that I'm not surprised once I get my DD taken apart, Can anyone confirm that once the hub is removed I will find another bearing? Is the procedure any different than the outer (less the nut).
