Old Sep 6, 2012 | 12:00 PM
amx1397
Default Re: Supercharger problem
11 Feb, maybe this will help the pic show a pulley
the silver looking washer is not a washer it is the spring ( flat spring looks like a dog bone)
there are since rivets. One holds One side of the dog bone Spring clutch and the other holds the other end of the dog bone, to the clutch
there's a picture of a Shim.
http://i264.photobucket.com/albums/i...g?t=1346947132http://s264.photobucket.com/albums/i...eyshow2003.jpg
pic 1 you can see the spring from Rivet to rivet from clutch to pulley
pic 2you can see the shims and where they go
pic 3 the larger looking rivets are riveted to the spring to pulley smaller looking rivets rivet the spring to the clutch
pic 4 riveting clutch to the spring
pic5 you can see the rivet Holding down the spring The spring is that silver looking thing that almost looked like a washer
pic 6 I took a screwdriver and lifted up the pulley to the clutch and if you look real close you can see the hiow the spring is riveted and it is a flat spring
hop this clears up the pulley and clutch
