Old Sep 7, 2012 | 11:04 AM
eruby's Avatar
eruby
Default Re: Coolant that will work with OEM Coolant
Originally Posted by dinasrt
If you're just topping up the reservoir until you get a new tank, I'll say that adding straight distilled water will be just fine. Just get it flushed and replaced before winter sets in.
1st noticed a low level (idiot light) months ago. Added distilled water then. Did not see the leak, just thought level was a little low. Now it's definately leaking and I added ~3/4 of a gal of distilled water Tuesday. Light back on today so I need to add more. Didn't want to add more water only - afraid it may boil. Probably used ~ 1 gallon of water so far and probably needs another 1/3 gal now. Not sure when new tank will arrive. Don't trust idiot light and I'm checking every day. Just want to add some coolant that won't mess anything up with my existing coolant. Thanks for any suggestions on this.
