Old Sep 7, 2012 | 12:48 PM
onehundred80
Default Re: Drivers side elec window issue!? Help!
Originally Posted by Chadders
Hi everyone, I have an 04' Coupe which has a temperamental drivers side elec window. It always opens on command when it is closed but then decides not to go up or down further when open? I have found out through messing around that if you open and close the passenger side elec window by 10mm increments, finally the drivers side elec window will kick back to life when pressing the drivers side elec window button! The passenger side window has no faults? Please help! Thank you in advance for any comments!
Could you lift the console trim and use the passenger side switch in place of the driver side switch to check to see if the problem lies in the switch? That would be a cheap fix if the switch was found to be the trouble.
