Old Sep 7, 2012 | 11:48 PM
closer9's Avatar
closer9
Default 100k miles. What else needs done?
Figure I'll be hitting 100k miles by years end. Starting a list of things to check/replace. Just wondering if there's something else you guys can think of that I'm missing.
Differential oil - hoping to do this weekend
Manual trans oil - probably do next weekend on friend's lift
Flex discs - gotta find some
Spark plugs - Need to do some homework. Always use NGK V-Power in everything else.
Coolant flush
Steering Dampner
Brake fluid
Check wheel bearings, steering linkage. Need to see if linkage has grease fittings.
and not mileage related, but must get seat heaters fixed in the next month or two. Also, need to replace valve cover gaskets (trying to decide if I want to powder coat the covers while they are off), and guess I'll go ahead and replace the oil level sensor. Too **** to pull the bulb, and tired of seeing the light. Will do that at the next oil change, so another 2 months or so. Also, need to adjust driver's window. Getting a little wind noise up front at highway speeds.
thoughts?
