Re: SRT-6 Supercharger noise
NORDVIK72
What I am stumped about is when i remove the accessory belt and rotate the S/C by hand the bearing seems just fine with no play. I used a stethoscope to trace the sound while running and its inside of the case.
You used a stethoscope while running and the noise was in the case? The SC was not running at idle and I do not know when it would kick in with no load. Anyway once the SC kicks in the bearing stops turning.
The noise would be transmitted into the housing though. I would expect it is the pulley bearing, the bearing turns on the bearing until the SC kicks in as I said.
With the belt removed there are two things you can turn, the pulley and the SC by turning the black magnetic clutch.
