Re: HELP: 100k mile check & replace
See below...
Maintenance Service Schedule "B"
£ Change engine oil and engine oil filter.
£ Rotate tires.
£ Replace dust filter ®
£ Lubricate hood hinges, latch and secondary latch.
£ Reset FSS Display.
£ Check horn, Hazard warning flashers, turn signals, indicator lamps, exterior
lighting and headlamps (adjust headlight aim if necessary).
£ Check windshield wipers and washer system. Replace wiper blades if necessary.
£ Check seat belts for damage and proper function.
£ Check hydraulic brakes and parking brake function.
£ Check fluid levels for hydraulic brake system, power steering system, windshield
wiper system and engine cooling system (check corrosion inhibitor/antifreeze).
£ Inspect front and rear brake pads for lining thickness.
£ Inspect condition of front and rear brake discs.
£ Inspect tires for damage, general condition and inflation pressure. Correct if necessary.
£ Inspect major underbody and under hood components for leakage or damage.
(If leakage is found, determine cause and repair).
£ Inspect condition of front axel ball joints and rubber boots.
£ Inspect condition of steering components and rubber boots.
£ Inspect condition of accessory drive belt.
£ Inspect body for paint damage (every 2 years).
£ Check chassis and supporting body parts for damage and corrosion (every 2 years).
£ Retighten steering locking bolts (50,000 miles or 4 years).
£ Check condition of driveshaft flex discs (50,000 miles or 4 years).
£ Replace fuel filter and air cleaner filter element (60,000 miles or 4 years).
£ Change the automatic transmission fluid and filter (80,000 miles). After this change it
is filled for life. Manual transmission comes filled for life from the factory.
£ Replace spark plugs. (1000,000 miles or 5 years).
£ Replace engine coolant using extended life coolant (1000,000 miles or 5 years).
