Old Sep 13, 2012 | 10:09 AM
ala_xfire
Default Re: LTB 74mm TB & 3in MAF
Originally Posted by Ronideas
Did you have to modify the E320 engine cover to get it to fit your XFire?
Only slightly : you have to remove a bit of plastic from the front to clear the radiator hose ( bench grinder ), and make a small cut on the driver's side for the vacuum line.
Hint : drill a 3/8" hole about 1.5" up, then use tin snips ( or hacksaw ) to remove the plastic ( for the vacuum line )
