Old Sep 14, 2012 | 01:07 PM
ala_xfire
Default Re: oil filler tube base gasket
Originally Posted by csteve0355
The gasket I need is the one where the aluminum oil filler base meets the top of the valve cover. Is this available or repairable or do you have to buy the whole valve cover with oil filler tube attached?
If it is where the tube connects to the magnesium breather plate, then this is the gasket.
( same as the gasket in the oil filler cap )
If it is the magnesium breather plate leaking, there is no gasket, search the forum and you will find a DIY with pictures on how to repair that with RTV sealant.
